Kev said:
I'm possibly exposing a massive amount of dumbness right now, but why do we not see innovation in the circular saw bade anywhere other than the teeth? (Apologies if it's out there and I'm simply unaware)
Things like replaceable outer tooth rings, etc or maybe some low profile fixing system for individually replaceable teeth. Obviously it would be horrible if stuff started flying off and the physics of this could be my simple answer.
Just curious [smile]
I am not sure if you are serious, or not.
I think that with better metals and better tooth design, saw blades for all types of woodworking have made tremendous advances within the years i have been working with wood (a few extended periods of not working with wood within the total time period stating when my dad gave me a workbench, saw and hammer way back in 1938 or '39). The last couple of blades I bought for my table saw gave a cut so smooth I barely needed to do any sanding. I had used several thin kerf blades, but they would begin to warp if the teeth were not perfectly sharpened (slightly dulled). When i switched back to regular kerf blades, I got much longer use. I understand there have been improvements since I retired my table saw back in the late 90's.
My circular saw blades I never tried thin kerfs, as i used my big milwaukee (8-1/4") for all kinds of work, much of it sawing into boards impregnated with cement and nails. when i discovered Festoys and drank the green koolaid, i found blades that gave silky smooth finish cuts. the only sanding I might need wood be to very slightly rough up the edges before glueing. Especially if i don't glue right away after the cutting. I have a SCMS that leaves just as smooth a cut. where can improvements be made?
Even cutting the very roughest and nail/cent impregnated lumber (going back 60+ years), i never had a tooth fly off (I don't remember when carbide teeth were added) of a blade. I did break many teeth over the years, but with my Festoy blades, i still find the occasional nail but have, so far, not even chipped a tooth.
Blades are stronger, the teeth are better designed and they cut almost perfectly smooth (sometimes almost too smooth) I have not gone back to thin kerfed blades, but i understand they no longer warp as quickly. A sign of better metallurgy. I think the improvements have been made in the correct direction.
Tinker
