I'm in the process of making some smallish raised panel mitered drawer fronts. The small sides were 6.375" long x 1.5" wide...
I wanted to used the 4mm Domino tenons to help with the glue up, but I couldn't clamp the small pieces to the bench in a way that the domino fence wouldn't interfere with the clamp. So I set to clamp the Domino in a vise.
I did a search here and found little of anybody else doing this so I figured I'd share. I suspect some viewers may cringe at this type of usage, but...
Anyways, using it this way, I was able to use the reference marks on the underside of the Domino for alignment. I simply aligned the outside edge of the piece with the appropriate marking in the base. I used the narrow domino setting, but I still wanted a slight adjustability in the joint, so I clamped the belt sander in the vise and kissed an edge of the 4mm tenons to narrow them up a touch. The results were fantastic - glue up and clamping was tons easier.
-Chris
Edited to insert space between images - Peter
-Chris
