CMS GE fence problem
Flackmistress
I am getting very frustrated with the fence on this router table.  I have the fence aligned parallel, and the near fence all the way out to "0" on the micro-adjustment setting.  Running my material through, it gets caught/stuck on the leading edge of the far fence.  I have no wiggle room to adjust the near fence out to prevent my workpiece from getting stuck.  I am unable to smoothly push my workpiece through.  When I force the workpiece through, you can see the "jog" in the groove where it confronts the near edge of the fence and gets hung up.
Any help?
What fences do you use? What plate in the CMS? Photos of your setup and the result might help.
Had the same problem and I found that the nut on the inside of the knob that moves the fence will change the minimum setting on the fence. If you alter it it will move the fence further out allowing you to align the fences in the "0" position.
I will try that.  I got uber-frustrated with it today.  For such an expensive tool, it is not friendly to get initially acquainted.  Thank you very much for your reply.
