Resurrected thread..
nachtwacht said:
Thanks for the reply.
I am actually thinking about doing the same thing with a TS55 or 75 (and finaly use it with an Incra fence) so am very curious what you did, if anything, with the baseplate. Is it just the baseplate or did you use parts from the table aswell ?
Thank in advance
I find this intriguing. I was idly thinking about something similar myself - buying a TS- 55 insert and dropping it into a DIY table with one of my Incra LS fences on it - probably the metric one.
I have a Beckum/Metabo saw table which is really a contractor's sheet cutter - about 6' wide to the right of the fence and It's FAR too big and unwieldy for anything I do though it would comfortably rip 3 by 4s all day. Evil thing but I love it, apart from the fence which has no fine adjustment though. I Incra'd it for a while which was awesome - but still a bodge. The main problem is I haven't enough room to spit, and this thing is the size of a car.
It's currently under tarps and piles of junk in the back garden. Since I
went tracksaw, the only time I miss the table saw is ripping sticks and battens and I was thinking about knocking up something (small( as per the idea above and maybe buying a "proper" cms table IF/when I can justify it.
I can hear the sound of palms striking faces up and down the Old Colony, but I'd be interested in any constructive thoughts and if nachtwacht or any other OP progressed the idea beyond musing.
I'm not sure how serious I am about this, frankly, but I like the challenge.
I'd go for a thick ply top with a full-size insert hole and then thicken it under the edge of the hole and glue/screw mdf lipping to the inside of the hole to take up the variable space under the insert and bring it level. A drop leaf and gate-leg (or whatever) to take the Incra and
Robert's your parent's sibling.
With a plain insert it could be useful as a saw stand when track sawing, or extending the MFT for picnics for extra plates of olives or pickles.
I'd think twice about hanging the nearly 13" blade of the Beckum in something like this, but I'm confident this arrangement, carefully made, would be safe enough for the envisaged use.
All responses appreciated.
