Jmacpherson
- Jun 9, 2016
Hi all
Trying to better understand exactly what the length and width limitations are of CMS TS 75 Module are without any of the extra extensions?
I found the following info but it does seem vague or I'm just not following it:
Max. working width for trimming cuts 830 mm
Max. working width longitudinal 576 mm
Trimming - When Festool state trimming @830mm do they mean that for example the max size board can only be 830mm X 830mm and you might be trimming it to 800mm on one side?
Longitudinal - again, would this be the widest board/lumber can be when ripping? Eg. Ripping a 2.4m x 576mm down to 2.4m X 550mm for arguments sake? (for something that long would need additional support)
Last question, which of the extension tables would be the one to add first and can you store them with a folded CMS or do you have remove them first each time?
