Tayler_mann
- Nov 23, 2014
So after reading for the third time of the FOG people having trouble putting two tracks together I decided next time I had to do it I would take photos and explain how easy it is. There's a few things you will need; a Mft table at least 80" roughly, 4 bench dogs, and a perfectly flat table. Step one: put bench dogs in a straight line in the Mft top. Two of them touching one of the rails and two in line with the other rail you are combining. Put the straight edge of the rails against the dogs with the track connection plasm yes in their slots. Tighten the top connector than flip the track on its straight edge onto your table top makin sure the tracks are square to each other and tighten the second connector. Your tracks should be perfectly straight with eah other at this point and it should have only take about 1-2 minutes. Below are pictures to show the steps a bit better.
