Graham said:
I have been looking at the CMS TS55 and and the MFT/3 as I do not have a workshop so need to be able to pack things away.
If you are in the USA, remember that the CMS is not yet available there.
Can you guys give me your advice on the following.
1. There appear to be two extension table on the Festool website VL and a VB-CMS, do you know what the difference is and is one better than the other?
Extension Table VB (Tischverbreiterung)
...is attached to the
right-hand side of the main CMS table. It also fits onto the right-hand side of the CS50 table saw which is another item not available in North America (NAINA)
Note that it has two support legs, but only one is visible in the picture.
Extension Table VL (Tischverlangerung)
rear of the CMS or CS50.
2. Any idea what 'support AF' is for?
Support AF (Auflage) is attached to the right of the CMS and CS50, and is simply a cheaper alternative to Extension Table VB.
3. If I get the sliding table (think it comes with the set?) do I not need the LA fence?
The Sliding Table ST (Schiebetisch) (which does come with the CMS-TS 55 Set)...
...is attached to the left of the CMS and CS50.
You would normally attach the
Angle Stop WA (Winkelanschlag)...
...to the Sliding Table, and then use this combination for cross-cutting in the same way that you would use a mitre fence on a simple table saw. Mounted on the sliding table, the Angle Stop moves back and forward like a standard mitre fence (see photo at top left of Page 6 of the
CMS brochure).
To do rip cuts, you can attach the Angle Stop to one of the four sides of the CMS to CS50, so that the fence is parallel to the blade, and then slide the wood past it.
Alternatively, you can mount the
Rip Fence LA (Langsanschlag)...
...to the right or left of the saw blade and slide the wood past that instead (see photo at top left of Page 7 of the CMS brochure). This fence clamps to the V-grooves at the front and back edges of the main table of the CMS/CS50, and is more rigid than the Angle Stop, which only clamps to the V-groove in one place. It also has a micro-adjustment, allowing you to move the fence a small amount left or right.
Forrest
