Complete Festool Boom Arm and Handle set for the CT-22 or CT-33 Vacuum - Kansas
sroxberg
Festool Part Number 452921 retails for $81 and is required to support the boom arm.
CT Dust Extractor Handle improves mobility for the Festool CT 22 and CT 33 Dust Extractors, helping you easily transport your CT to and from the jobsite, or from one shop station to another. Constructed from durable steel tubing with high impact plastic mounting brackets for a long life. Mounts to the rear of the dust extractor.
Festool Part Number 492753 retails for $290
Use the Festool CT Boom Arm to keep the cord and hose up and out of your way for more efficient work during sanding, sawing, routing or planing. With an assembled height of 7 ft and a range of motion of 140 degrees, you will virtually eliminate the headaches and inefficiencies associated with tangled cords and hoses. Stabilizer bars straddle the base of the CT Dust Extractor for secure and stable use. Constructed of durable steel tubing for a long service life. Includes a 5 ft electrical extension cord and a 50 mm x 5 ft Antistatic hose with female coupler, allowing a good working length off the end of the boom arm when coupled to the standard 27 mm x 3.5 m hose supplied with the CT Dust Extractor. Requires handle (452921) for mounting onto the CT 22 or CT 33 Dust Extractor. For CT 26 or CT 36, you will need to purchase the CT handle (495802) and Boom Arm Support Bracket (496780).
These are used but in excellent shape, Retail new price would be $371.00
Asking price is $270.00
The item is located in Overland Park, KS but I will be in Stillwater, Ok, Des Moines, IA, Columbia, MO, and Iowa City, IA all within the next five weeks.
I am willing to ship but that would have to be a separate conversion on the cost.
THE DUST EXTRACTOR IS NOT INCLUDED, THIS IS THE HANDLE AND BOOM ARM ONLY. it will include the 50 mm hose, and extension cord, and stabilizer.
