Hi there, I need advice about a compressor for spraying solid wood and mdf for my small workshop. The compressor I am considering is Atlas Copco AB40E270T, FAD:344 lit/min, 11 bar, 3 kw/4 hp, 270 lit, 112 kg, 79 db, 400/3/50. The compressor has aluminum pump . I alredy bought devillbis gpi spray gun wiht 1.4 and 1.8 needles but I have zero experiance with spraying. The compressor will be used mostly for spraing in one man wood workshop. Any advice is most wellcome, thank you.
