Computer Carts Starring Domino XL
Crox G
My son’s school needed three carts for transporting and charging laptop computers. We were able to design them to hold 24 each.  I used nearly every tool, especially my Festools, to do the job, so the project was a success in that regard.
The carts store the laptops on their long edges, divided by rows of dominoes.  The cords and power supplies are stored in a parallel trough.  The power leads feed down through holes to three power strips below.  Those strips in turn plug into a quad-receptacle box, which is fed by an extension cord plugged into a recessed male plug.  I hope the expert electricians approve!
[attachimg=2]
The bases on two of the units consists of six panels each, all 800 mm by 600.  How about that for lazy!  On the third, for smaller computers, I made the end panels in the golden ratio, 494 by 600.  The sides of the top sections are about 150mm tall. This was a good exercise in my conversion to metric.
The TS55 was a joy to use on the domestic baltic birch 18mm plywood.  With my Parf Dogs (thanks Peter Parfitt!) all the panels were square and true.  I fastened them with self-tapping screws with Torx heads, using the Ti-15 (i love it), and rounded over the edges with the 1400 router.
The Domino XL was the star of the show, however.  I wanted parallel rows of equally-spaced dominoes, fit within the 800 mm length.  25 dominoes to support 24 computers came out comfortably at 32 mm on centers with about a 10 mm margin on each end.  I decided to use 10x50 dominoes and found that I could index each hole from the previous one, using the tall Parf dogs and a 12 mm spacer.  I had a leftover strip of 12 mm sipo, which worked perfectly. There was no appreciable cumulative error, but just to be safe, I used the first set of holes as indexes to make the second row of holes. I used the Domino's first indexing pin for side spacing.  At 100 dominoes per cart, my supply went fast. Thanks Bob Marino!
[attachimg=3]
I wanted to notch the top of the divider, in between the dominoes, in order to have a place to park the charging cord for each laptop when it is removed.  How to cut a 7-8 mm slot in the edge of the plywood?  I didn’t trust my table saw technique or my router, either hand-held or table mounted.  I had the Ahah moment and tried the Domino held vertically.  I used Rick C.’s self-centing guide and an 8mm cutter with Seneca adaptor.  I just worked to an eyeballed line, which was close enough.  It worked great, with just a little tearout on the edges, easily sanded off with emery paper.
[attachimg=4]
The leads for the power strips looked sloppy. I wanted to hide them in the unused hollow space between the two supporting sides.  Domino XL to the rescue again!  Three 12 mm slots cut just above the power strips allowed just enough width and length to cram most of the wire out of sight.  A couple of cord clips and zip ties made a much tidier job.
Before:
[attachimg=5]
After:
[attachimg=6]
[attachimg=7]
I sanded the panels with 220 grit on the ES 150/3, and eased any remaining sharp edges with the RO 90. I drilled shelf pin holes on the side opposite the power strips using a plastic Rockler jig and self-centering bit, but boy did I wish for an LR32!  Finally, the Festool countersink with the hole in the side made a nice clean job for the flat-head bolts for the casters.
A fun few days in the shop.
Well done, thank you for some ideas. (I also own the domino df500, but i have problems to point the domino mortise exactly to the position i want when there is no guidance.)
I probably would have used long dowels where the Dominoes were use for the laptops. ;)
But I see that RTS job, and that is new to me.
Based upon the picture it seems likes the SCG-10 fit the XL.
It looks useful??
Gosh--thanks for all the nice comments, guys.  [big grin]
Chris Wong: I'm talking about cloth-backed abrasive, 120 grit, blue, that I have in a 2-inch roll.  I use it a lot for turning.  Maybe I used the term "emery" wrong.
Holmz: You're right.  Dowels would be cheaper and probably as effective, and one could bore them accurately on a drill press.  Nice catch.
Cheers,
Crox G
I could actually bore them by hand stacking and clamping the boards and usually a jog to keep the drill normal.  [cool]
(And because I was computing the Domino cost)
For truth in advertising...
This looks familiar as I often tell the Mrs that a job like that absolutely requires Dominos, and hence justifies a specific new machine. [wink]
[member=17405]Crox G[/member]  Is there only one plate that fits both the DX700 and DX500?
I would hate to get the wrong one (DX700).
Your project has given me some good ideas. [TH]
@ Holmz:  Look at the RTS Engineering website at dominoguide.com.  I don't see specific models of the Self-Centering Guide for the 500 and the 700. I'm sure Rick would respond promptly to an inquiry. He's great to deal with.
Great design, lots of lateral thinking.
One question is that an elastic band around the tall parf dog? What does it do? :)
It looks like it goes around the long tenon piece. My guess is that since that piece is a domino and has a rounded bottom, it just keeps the thing from flipping over when he moves the workpiece and the domino
Bingo! What he said.
It took me only 20 minutes of watching it flop over, cussing, re-setting, etc., to think of it.
Very nice build. I like using the Domino for the cord holes,much better than a round hole. Good idea
Thanks, Jack and Chris.  What's the saying about if all you have is a hammer, the solution to everything is a nail?  I look for any excuse to use my XL, and it has served me well.
