Conturo Error 10
Ric Lambert
Hi All,
I am getting an error message # 10 on Conturo is turn on from cold startup. Machine will sometimes shut off but not always and does not heat up to temp. I have checked all fans are working ok, all good.
The only I can use machine is to open glue lid void as if loading glue puck and wait until machine heats  up to working temp then close and run back glue press, the machine works fine after this operation.
Does anyone have any ideas why I am getting this error 10 message, machine has only be used about 10 times over a year.
Error 10 is an issue with the cooling fan. I recommend that you contact the service department in Australia. 1300-063-900
