Cool large size scraper on sander
Seth,
That's not a stripping machine.  It's quite obvious it's a Linear...... Powered Snow Shovel.    or PSS300
Seth, Defintely not a stripping machine as there is no pole. ;) :D In addition at approx. $554 US I would expect it to do more than strip, eh?  ;D :D :o Fred
    Perhaps it could be used for that yard / garden work that was in another post?  :-\
        The pole is an accessory.  :o
          And there is a Systainer to hold paper money all sorted out and ready to dispense :-X
      Anyway the thing does look pretty cool. I first thought that it might be able to sand at the same time. Combining two operations into one. But it looks like the frame for the scraper  attaches underneath.
looks like the LS130 with a scraper attachment; is that what it is? and where can you get one Bob ?
        thanks
        Dan
        thanks
        Dan
The pic in the first post will disappear some time after the auction closes, so here's another:
[attachimg=#]
The TPE-RS 100 is derived from the RS 100 sander (NAINA) and is built to remove carpet.
[quote author=Festool UK website]Strengths and benefits
    * Hand-held use for awkward spots and stairs
    * Extension handle for non-tiring work over large areas
    * Powerful stirring action and reduction gearing for maximum economic efficiency
    * High area capacity: 25 m? per hour on compact foam-backed carpets
    * VS balancing for low-vibration work
Main applications
    * For removing:
    * Carpet
    * Backing layer
    * Adhesive layer
[/quote]
No 110v version is listed.
Ned
        thanks
        Dan
  No, but there is a scraper available for the LS130.  491 199
