Cradle of Pau Mulato
"Cradle of Pau Mulato" has a ring to it like "Shroud of Turin" or "Eye of Fatima".
I just do not know who Paul Mulato is... ;)
Calycophyllum spruceanum, common name Capirona, or Pau Mulato ,is a canopy tree that grows up to 30m high. It sheds its bark periodically. It has smooth light green bark when it´s new, dark brown when it´s old. The dried bark is used to treat fungus on the skin. Used also as an antidiabetic and for eye infections. This tree avoids lichens, fungi, epiphytes and lianas, by getting rid of its bark. Once or twice a year it sheds off its bark entirely. The smooth green bark underneath is somewhat like a sunburnt human. The older the tree, the more of its bark will be unpeeled, creeping up its trunk. It grows white or green flowers between March and April. It fruits between July and November, seeds are dispersed by the wind and water.
Calycophyllum spruceanum grows in the South American countries of Bolivia, Colombia, Brazil, Ecuador, and Peru.
Edward A Reno III said:
Beautiful work.  How did you make such long box joints?  Did you use a shorter template that you moved over, or did you create your own jig to do it on the TS/router?
zoki4691 said:
THX Edward
U can see on film that has been made two passages .
The same type of joint used for the cradle , and drill 6mm
Only problem interlocking not be somewhat longer than 590 mm !?
leigh f3m
