Hi there,
I have just started to design a combination workbench that I can use for a number of uses. I've been following Peter Parfitt's mobile workbench video's and been reading through as many mobile MFT threads that I could find.
My requirements are to build a mobile MFT base that has storage for hand tools and MFT accessories. I also want the ability to be able to remove the MFT and use a moxon vice. A 6" jaw height would put the top of the moxon at about the same height as the MFT is normally, 900mm, which feels about the right height for dovetails etc.
I've attached a zip file of my Sketchup in case the JPG's don't give enough detail.
1. I followed Peter's dimensions for the base frame and then decided on the laminated top which might now be a little oversized for the frame? I've been looking through Chris Schwartz' Workbench Design Book and have tried to cross some of his ideas with a mobile MFT base. Chris notes that a worktop should be fine just sitting on top of the frame, perhaps with some dowels/dowminos to locate it. Uprights are 50x50mm, rails are all 30x45mm, just like Peter's Kapex table, which might be undersized given the top thickness?
2. The table is designed to let me use my MFT by sitting it on top of the table. The model is missing the castors which are 125mm high so the height of the MFT will be the same as it is now, 900mm.
3. I decided to buy some holdfasts for work holding and leave off a vice of any sort. I saw this video (replace_with_www.youtube.com/watch?v=WNrof3cd1cA and thought it would cover my needs until I build a bigger full size bench. This is why there is an empty tray under the table top - the holdfast is ~13" long.
4. I will build a Moxon vice/mini bench to sit on top of the table (after removing the MFT) and be held in place by the holdfasts. I can use this for cutting dovetails etc. It will be at the same height as the MFT top which feels about right.
5. The two sets of drawers are on 700mm full extension slides so I should be able to store a lot of handtools.
Thanks, Shareef.
[attachthumb=1][attachthumb=2][attachthumb=3][attachurl=4]
Thanks, Shareef.
