WarnerConstCo.
- Apr 14, 2008
Finally got my Oliver 103 pattern mill running and used it for the task I bought it for.
Sent from my SM-N960U using Tapatalk
Thanks, both links/previews showed up in my OP. HmmmmmRJNeal said:
Nice Darcy. What a beautiful machine.
No link in hot post.
Hopefully this works.
Rick.
Pattern mills are fairly rare anymore and I figured sharing a unconventional way of crowning tires would be interesting. I did a set of 36" ones as well. I need a hoist to lift heavy stuff on the table, I couldn't lift up a 36" steel wheel by myself.RJNeal said:Thanks Darcy for sharing.
I just found the crowning video by you tube search of your channel.
Your tool always fascinate me. I’m all for old iron versus new tools with less quality.
I currently own a Boice crane drill press from the early 1970 and a 1953 Northfield 8” joint. I can’t wait to get these up and running in my new shop. They been back in storage for the last two years.
Rick.
Some are. The little 16" wheels had a crown machined into them, but they still required a clean up to true them, btw those sucked to epoxy tires on as they wanted to pop off.Cheese said:Well, being unable to see the video, my question is rather than crowning the tires, why couldn't you crown the band saw wheels instead? Just machining a slight curvature to the wheels would also translate the curvature to the tires and thus control the tracking of the band saw blade.
WarnerConstCo. said:Finally got my Oliver 103 pattern mill running and used it for the task I bought it for.
All tooling is mt4 with a draw bar. The chuck was just in it when I got it. They were using it as a drill press. Lol.Cheese said:Thanks Darcy, that was pretty interesting. [big grin]
Two observations;
In the first video the use of the Jacobs style chuck to hold the tooling.
In the second video the ease at which the table rotates, it's just a one handed affair.
I have had at least 10 people ask that. Apparently there is a demand, I just loathe shipping large obsolete wheels.Michael Kellough said:Thanks Warner and Alex. That machine is awesome! Makes a regular milling machine envious.
You gonna offer a wheel truing service?
