I'm hoping someone might be able to help. I have the right hand extension table for the CS70 (CS70 VB) and I'm finding it impossible to calibrate the measurement scale to the main table.
The measurement scales are movable by loosening some small screws that enable the scale to be moved by a few mm left or right in order to calibrate the scales.
The problem I'm having is that, after calibrating the scale on the main table, there isn't enough room to move the extension table's scale across to the left. In using the rip fence, the scale is showing about 2mm less than the actual cut.
If anyone can offer any tips on calibrating the extension table, I'd be very grateful. Surely it should be more accurate than this?!
