Okay, so here's a good reason to clean your garage - you discover outlets you never knew existed!!
So, got excited because the outlet looked like the plug (without adapter) on my CT22. I thought my continual trips to the circuit breaker were over!
No such luck turns out the plug is a NEMA 6-20 plug (apparently often used for motel air conditioners - what it's doing in my garage I have no idea). As far as I can tell this obscure plug does offer 220 and likely a dedicated circuit (though I haven't tested that yet) but on the downside virtually no adapters.
So . . .
I'm thinking of swapping out the outlet for something more useful that I can have a step down adapter for my CT22 so it gets a dedicated circuit. I currently don't own anything that requires 220v.
What are people's advice for swapping out this outlet? Should I ignore the second leg of power and just wire it 120v, label it so I don't forget it could be 220 if needed in the future, and be done with it?
Or is there a better 220v outlet that has readily available adapters that I can use to use it as a 120v circuit for now and a 220v in the future as needed.
Any advice would be greatly appreciated.
Thanks,
Anthony
So . . .
Thanks,
Anthony
