CT 26 Extra Socket Outlet
It says "Festool spare part - Module - REQ PLUG CHANGE".
Not sure what that means, but it sounds pretty plug changey to me.
Perhaps [member=19280]powertool-supplies.co.uk[/member] can help - have you rung them yet?
I just emailed them about this.  It is a standard part, but they need to change it to a UK socket.  I mentioned your experience and they said it must have slipped through unchanged.  I'm sure if you contact them they will correct it.
[member=12707]russandnit[/member]
If you are selling that "EURO Socket not a UK 240V 3 Pin" then I'll take it.
Haha, this is begging a comment on how the Brits should get in line with the German socket  :P
496405 is the same part number it has here. I assume Festool only has one variant per part number, so yes, that would be the "normal"  [tongue] socket.
I assume you mean it has the Schuko socket? Euro socket implies no grounding, accepting only the thin Euro plugs.
AFAIK, the "inside" connections are identical. The top connection block carries the power, and as the UK, EU and AUS all use nominal 230V 50Hz, I can't see any reason why you could not use a secondary EU socket (or GB socket) in your AUS extractor.
