KentonIwao
 - Jun 25, 2011
Hi. Vac failed to run. Disassembly showed brushes are short but still have carbon left. Bench tested turbine and it fires up.
Bench tested control board: In Auto I get 120 volt to the aux. plug. In Manual and Auto I get 34 volt to the turbine.
Does anyone know the voltage specs for the control board? Or any advice on trouble shooting power to the turbine.
The stator(field winding) assembly seems to be slightly loose have a little play/rattle.
Thanks for any advice
