Jaybolishes
- Apr 16, 2012
So I got my vac in May, it's seen moderate use. I was vacuuming dust off the floor when the autoclean feature engaged even though the setting was at zero. It had done this many times until today, directly after the autoclean cycle, the vac stopped working. The plug on the vac does work however on auto setting, so my sander will work running through the vac, but the vac won't turn on. The vac won't run on the manual setting either, which was where it was when the vac stopped.
Has anyone else had issues with their Ac vac. It seems the problem arose due to the autoclean feature. I'm taking the vac now to my dealer for servicing, but I'm nervous now after three years if this will happen again.
