CT Midi not working right
WoodWhisperer
I had my Kapex hooked up to the midi today.  All was good then no suction.  The saw was plugged into the midi and still running but the vac was not.
I turned the switch off and on a few times and it started working again. Weird I know.
Any takers?
Sean
Sean,
It's possible that you tripped the heat and overload protection in the CT, which will disable the motor until it gets back within normal operating parameters.
Shane
I was wondering, if the heat protection was tripped, does it also shut off the tool outlet?
Shane Holland said:
Sean,
Shane
Thanks Shane,
That could be it.  Its never happen before and I used it all day today with no problem.
