Using a cyclone with CT 36 in auto-clean (AC) mode is pointless for concrete/grout/tiles work. I personally consider it detrimental even.
It makes sense for plaster/drywall where you have lots of fine@heavy dust which is optimal for a cyclone AND you do not care for the cyclone choking your vac a bit.
For concrete/tiles you will have most of the dust as bigger particles which means two things:
- cyclone choking your vac will negatively affect you, unlike with drywall work
- you are -not- really helping the filter, as the bigger dust will anyway fall down in the bin immediately and never reach the main filter, again, unlike with drywall
Due to the big particles, you need all the air volume you can get there. You do not really want a 2" hose combined with a cyclone choking the CT. The speed of air in such a setup would be too low in the hose and the heavy sand will tend to accumulate there.
I was grinding down a brick wall last weekend with my CTM 36 AC. it was crazy as the wall was like a concrete wall with brisks inserted - too much cement in the grout ... and ... it handled it absolutely fine. And that was a wet wall /basement, no insulation/ so I was really afraid the dust "sticking" in the main filter and re-forming concrete there. It DID create semi-concrete blocks in the hose start, but the filter was absolutely fine. I used the "middle" AC setting.
Just make sure you monitor your bin - you want to empty the bin when 1/2-2/3 full, not more. This is not like with bags where going 90%+ is absolutely fine. Bagless operation needs some space to allow the dust to settle in the bin and not "rotate in the wind" below the filter.
Also, even if you have M-class with the flow sensor, do not rely on it to tell you when to empty the bin.
It will sound the alarm too late with the "correct" hose setting and if you set it to a 50mm hose setting it will make false "alarms". The sensor is more a safety thing here. Works reasonably well for bag operation, no so much for bagless rough work.
[member=73094]afish[/member] Just noticed you mention bags: Forget them for this.
When you have AC vac, you do not use bags when using AC mode. Using bags is a band aid for this type of work when one does not have an AC vac. When you have AC, you use AC, not bags.
If you still have only one main filter, get a new paper/nonAC filter for bag use and dedicate your old PET filter for bagless use. That is the most economical. Trying to clean a main filter after bagless use is pointless. You need one dedicated for such use to get the best of the AC capability of your vac.
What I do is:
- remove a wood-dust bag from the bin (carefully) and the paper non-AC filter
- put in my AC HP PET filter
- do the work
- empty the bin, remove the HP PET filter (AC-capable)
- clean the bin, the filter holder and any hose end/etc. as applicable
- put back the bag (with dust in it) and the paper non-AC filter
- vacuum the PET HP filter a bit, so there is no dust falling from it and then store it, I do NOT attempt to force-clean the HP filter, as there is no point and it would only damage it
GL!
