CT22 and HL850E Planer
upscale
Hi, I'd like to get some opinions on the effectiveness of the CT22 dust collector coupled with the HL850 planer. How effective do you find the dust collection used with the bench unit and not used with it?
I've already got the CT22 and am considering the purchase of the HL850 planer.
Thanks.
We've been using the 850 with the CT26 and the 36 mm hose, inside an occupied house, while installing doors. DC was great.
I've never used the bench unit, so I can't comment on that.
Hi Upscale
I have a CT22 and a HL850 also the bench unit
You will need the 36mm hose or it will all block up
When you use these in the correct combination your planer and vacuum will all work perfectly
Regards
Meatman.
When you use these in the correct combination your planer and vacuum will all work perfectly.
Thanks everybody, appreciate the quick response. Looks like the planer, the bench unit and the 36mm hose will be my next purchase.
