**Hello everyone,**
I’m running into an issue with my **Festool CTL 48 AC**. When I set it to *Auto*, it powers on straight away and just keeps running. It has the Bluetooth button, and if I press it the extractor briefly slows down as if it’s about to switch off, but then ramps right back up again.
Luckily, I also have a **CTM 36**, so I swapped the faceplate over to check whether the problem might be with the plug socket, Bluetooth controller, or main power switch—but everything behaves exactly the same.
Has anyone come across this before? Any suggestions would be hugely appreciated!
Hello everyone,
I’m running into an issue with my Festool CTL 48 AC. When I set it to Auto, it powers on straight away and just keeps running. It has the Bluetooth button, and if I press it the extractor briefly slows down as if it’s about to switch off, but then ramps right back up again.
Luckily, I also have a CTM 36, so I swapped the faceplate over to check whether the problem might be with the plug socket, Bluetooth controller, or main power switch—but everything behaves exactly the same.
Do you want me to make this sound more like a forum post (casual/help-seeking) or more professional/technical (for Festool service or repair groups)?
Hello everyone,
