Graham,
I don't have any photos of process work that far back for me. I "bent" rails in the mid '90s and did not have a digital camera "back in the day". Maybe I can build a mock up and photo document it.
I had these two old guys from the union that were members of some guild that squared me away on bending geometrics as we call them in the States. The system we used was an L J Smith stair system out of Ohio, USA. The manufacturer devised a 7 piece interlocking ,via a tongue and grove, rail and a form made of two pieces that were sacrificial for clamping against. This technique requires lots of "jergie" clamps. One clamp to pull the build up to the "T" forms attached to the stairs at the center-line for the balustrade, usually a 10" clamp. In between the forms we use as many clamps as we can place to pull the gaps closed and help smooth the radius. I have used this system for bending all radii that I can not cut but the biggest advantage, as with your project as well, is that you can transfer the roll of the profile as well.
