Custom Sharpening Tools Organizer in Systainer SYS5
ryanjg117
I recently purchased a lot of systainers, including a couple of SYS5s. They’re so deep, I’ve been mulling how to use them in the shop. Well, I’ve accumulated quite a random assortment of sharpening tools, so I thought it would be a good challenge to try and fit it all into a single SYS5. I had to use some ingenuity to get the large stainless sinkbridge to fit, but I think I’ve got it all figured out:
5FTm-evag29LpPqsgPX7E1O6tKHNaUhj3ex3fz7vT7_nsgdczxxh3WohBGv24cmz-RAQVRz4mKUFvpfUqUu8r4Yz1eW4AX3-9WthPYa23WzLfM9dQxe4jlNM0zbwe7c2lkRA4bNTMfiyNqNwzuAM7zl0DFXHBWrrrVlwAkDfQNTvBzf1qTmlXXvC8DqMmwdEX0KIh-3eYYT5n6pgh9qId56iIdZiMmk7mIwydlTVjjQf6W5v9BWi95PZObUdKonoeKsLRNihzadMEZtucapYmQODITKDsWrk5HHgJTorXUMwmYvKyb3DQUGEZDOVxkoyHLY_GyJBZM-I5m6-q--Vy9vjCimoGautKCLP1bKcBTm6HBaupJ-EeJmKlzFPXsWpCZXL_1uVOkL_QPXUpfMHm6ZGoMwEhuqpTpc89j4XXPkV1hBm90GEvRokoGfsY_UkfhMAvReHt1J9MAd3c-oK0RaWP2ni8KzOPohLIVl9a4hVUx2IQCDo0f279bDzfYyp6S8HnDSIdtxIah1ebUq2CysUTveCcvtcDuYJFBYKOdowKbc4-at-O0uOco-fLqzWZ85PSj7krCW7Wu7Uo1pa-ufenmrlGcy8vH5DW9FolSJk7P7n=w1000-h1024-no
Zze4ll2OzfhkQd4k45OuYCtnsGDAzBCf-2gHWbl35IFcyzPSxV9QaqCMxD19KuVKisdBR3c4_n58TsnezL_aEadQBGA6cCokrfBblzGnpH-MAovgEWTTSj_u_hH23yqlqja_dgDCiyPNMvrZtnkmqnvEExWmQHzrrmUhZ-Nin0s75zkaP1Pkjzg_5-qEfimUsvAwLt-N3wHvSDkzl-172E9jUlZP87XUo3fBAI9oMqKwdUR0DVHKJNDHUXUNsfUO42hPmW1dI4B6VrSrTuVDW7qH6rB2pHMjHzTZN_W9XLe8YAi3R-HvpXTp-lUrla_-A3sIFK7RQYYmq1JOIfLbVq3BqygZlScJJJwr_iJmJYJZpWVpSV7p9tJa1Pqg_s-HJtoauXfKDrX1l9PiOyoaUyioWE5NK3Dkkmg9-J_uOPLtOAj1blhG4qnyUdEu1rnCM553i4MSmafKPUOrAHHMeBFnSvXznvuqtm5Nv_lUmTIp96ZSvt3jw0-_KXIsLJcdZ7wPZ6VMJenMYj2xscwojbHlBwJ47Po34l8hz7WptNWu4P6ymTiguMSZK8L1FySd6ZjrxUtD2wnnKXODUL07pqOeGt9dpMld6OvkLh6Fywpt3cIE=w1000-h1012-no
zp_kIdwBt_6O2qGopDpKqiUJf1RgKr5anbJHiMd9SKXqx2uno4JEtlYzXN9zTEi2PKi-_K3YLBha7NdeUTJCVffNx1y74hZZExBnbrBGWmy2kQz9vBAZ-vdZ76cPfTAPYqxRMJe-1mQwPHEX2XEsKuG6FEO9htH_0tlB4l-K5c-EDCt0HmwsTSjOxnxLdLKl6aXq73nGq_Gxt-gCnBe8-GhUwHWPP3V2tQOP9N_V_x0fm20TdWy4U_DZ8g1XlBeNbtrw0ncjcguN-TeX9Efe5YYtOau4AsTBjiDkesGLawUpO8zw0SiwEEG9ZAsyUP_u8utPdXbzuIwNY-CuCd0lalrSSwmYU1T8AhpD6RlyuhcQbfWzz8Tv0SpK77pASa7fvcIw6aP4CBbSBWOgAYviKJtXjcwoRgMDPpvfBCOxAKflfYTb17_H2QC_RfrW5J4hxN9snKZLemjK7pwvS8OYJ6bozhYNb04HycHpOniz1IcoJ293Zz3PSLYDx3xhhyVjjpL3QIYAbNNa7m0pvu3x38dvyEAKI-OmXjVTMKvqA3gHxQJg_MOMYC08EMYWFzQDJZpbcTM93xGyEeN1gSbaD8pG5I7sRCvc7AhMWvgn9pVR7Hb7=w1000-h988-no
86w-bcL00Ox2JWUTSfPuR8wNHVraIWCv6AXtj9kXk4zrcRcOAWUXRbSOZreeqX14WzkKmpGmu3sjwYMwTg27mtXTnZh5aoUa-sBFEH9GGyEj7yUTc3mMtjWTfZprKS2hmdceoM_Se4bk8MM-f9VwKpjpAYoB0LYp792NK4DPjKwr2tqv0foFQKUA4ahtAWt1dCo67h1yc82IZxgEI0g-OqRmTxePPoBuI7078oAgRhMNOBNIADAOrGuGTiCPqekhi1uLu3LnP6HBpZJQf4ZNGpe2HtOLiWTYvk3Qi_9r49fXfqMzGV3HzHOKnbhVGRgO-p8QrdXl39ApU9i1uweus34agH3qnG2wPas1n9mCtoZrXTUlzijy6OBrUrKFqJCMXgOKC1I95TOMRgLKuI8y76k2DUeBk3t9nztHvh8Lj9_9Xq61-aqoDSJuOLua8gupr5MnlD6w-QEExSBCjAKC01Ud7pl3P5kZ2wa10cngTdAtuPVcUllOTc6of4TCeSd2C7T0WJd02wZqD_iQ5XnBkR3eYFePbuYlIE4bI-lrP96F9APm0Ezkzm-ATzPFRGN7fII23qcWyLpgzLwJ7AescbG6rh8SkjjQvGX9wJ_9EkcPgF6c=w1000-h1006-no
wg6xv1rK0txx6ep8bc5IZBWCbgPe97wSLsHVa6Xf8_P9VD6GrSKPIEl58iKlK_8Q2hmU9kPLrz_Odoy4qoQqlA1-VonNg-cZmo1Rzs_fcoGYz4rIekglQFjkeQ-YrJM16XbZcv_E7mLGhQ5C8NXdDJI7fGB_YX_aMD_ccnrgCyYku3mH0WUIseMxjXZu-vsJm3_X8jDOUV76Y0n_3QMPMl_vuaTRnZkPAt_beMELlz-PagD6_RnTjlg_T_FLDKWvuYq7cL2xaMiAbihhRwXMbssGymMaXgW1i_TSYRZDXgne7yJBd08v1R3yBQYFfVGm8uC0yAdtdF8iEccMT6-23qpNEmasBBD1K-a7brKsD-zl7Er0MGNInN4LJdsIqnCJxTiKPyHa9TztAXysKBGx6zxF5P_eDTtHm5_CdI4lZfmGPDDmL-TdC9Zqc7wVVEtiKM1H9mpZ8x0mLWzOJ1X0z_IRGt8KOWo_xe3Tfk0dB7bx08ISERv9srnCFurMP4yCgs0_HMGN3bWyDXuY4sys9ckXaL1iqKmUgtD4dZmwYebsI5RJeeB7RP_i-GTbC3VeOFFI8tQEq_6g91bKmWw8p8pSgNzXmxrNeSubxaQbjSlyVemW=w1000-h903-no
The organizer is designed with 12mm Baltic Birch plywood, with some of the finer components made from 9mm Baltic Birch. I have a friend with a full-size CNC router and he’s kindly offered to help me cut it. It will be a fun learning exercise. Because the minimum bit size on his router is 1/8-inch, you’ll see a few exposed fillets around the joints. I could plug these, but I actually like the look of it and, really, it doesn’t need to be watertight. I’ll think I’ll keep them open.
If you’re curious about the sharpening tools I use, here’s a list:
• ChefKnivesToGo Stainless Sink Bridge
• Richmond Strop Base with Balsa Wood and Bovine Leather Attachments
• Beston 500 Grit Waterstone
• Bester 1200 Grit Waterstone
• Suehiro Rika 5000 Grit Waterstone
• Atoma 400 Grit Diamondplate
• Norton Stone Flattener
• Nagura Slurry Stone
• Richmond 1.0 Micron Diamond Paste
• Idahone 10” Fine Ceramic Rod (~2000 grit)
• Loupe Magnifier Set with LED for examining blade edges
I’m still a beginner when it comes to sharpening, and actually got into it to sharpen kitchen knives, but it’s a good all-around skill that has its benefits in the shop, too. I never knew my chisels could be so dangerous!
I have about the more empty systainers that need to get filled with something… If you’ve got a good idea for an organizer project, let me know!
[member=51886]ryanjg117[/member]  - what can I say? - functional, creative,  esthetically beautiful, professionally executed . . . (am I forgetting a compliment here - help me out, please)
So tell us what you do for a living and what you studied?
my hat's off!
Hans
TSO Products said:
[member=51886]ryanjg117[/member]So tell us what you do for a living and what you studied?
my hat's off!
Hans
Hans, I don't do this kind of work professionally, just for fun. Transitioning to parametric modeling requires a different mindset, but once you have the fundamentals down (sketching, extruding, texturing), it actually becomes pretty simple and fast.
Hi there , very nice work.
Could you design an insert for sys5 that would hold 3-4 festool drills. For example t18,cxs,c18,bhc18 ?
Thank you.
All done! I learned a lot about CNC and CAM with this project... Namely, that I need to offset my joints.
Incredible work. Did you cut them out yourself?
How many hours in design/cutting.
Thanks guys. I had this cut on a friend's CNC machine, and made a few mistakes with my calculations so it took about five hours of detail sanding with a Dremel before it all came together. I'm actually not super happy with the fit in the SYS5 (it's too tight), and I might re-do the entire insert.
To answer the questions on the corks: they're used to de-burr the edge of a knife before you step up to the next higher grit stone.
Hello,
Which software program do you use to make your renderings.  They look outstanding.
Thank you
