TSO Products said:We're thinking about an intermediate size worktable, larger than an MFT but smaller than Ron Paulk's 4ft x 8 ft super bench. Something like [member=42009]gunnyr[/member] has in his pick-up truck. We would be interested in hearing current user reports in a new thread on that topic.
Hans
Peter_C said:Both of your setups are far fancier and heavier than mine. I even complain about the Toughbuilt C700's weight, but their adjustability is awesome.
I just use two 2x6's and some 2x4 material. The top of the C700's have the 2x4's screwed down. The handles are still usable too. I cut pocket holes into the top 2x4 material, but have never used them yet.
Michael Kellough said:[member=63307]TrackTubesGuy[/member] great system you built but what about dust collection? Do you use a sacrificial sheet under the workpiece?
One other thing I did was to remove the top grip stuff on the C700's, with a heat gun. One was already falling off anyhow, which is how I got it for 1/2 off. Even still the 2x4's on the outboard sides requires a shim. Sometimes I think of cutting a 2x6" down to the proper width which is about 1/8" wider than a standard 2x4". I used 3/4" screws so I never have to worry about nicking them with a saw blade, and am not worried about holding strength with the 4 GRK screws per board. As they are sacrificial, I just replace the top 2x4's every so often from off cuts. Many times I don't bother with the side and middle rails, but just use them as saw horses like most people. The dust collection is good enough for me without foam. *shrugs*gunnyr said:I also have C700's. Like you, I put a 2x4 on the top of them but I covered up the handles. I've been complaining ever since about how hard they are to carry! I'll be adjusting my set up soon! Many thanks [member=62526]Peter C[/member]!
RSU said:My use for this is mainly outdoors. If I have a need for better dust extraction, like setting up shop in a Customers garage. Yes I'll throw a piece of 2" foam board on it. I just drank the green cool aid. Last month with a TS 75. And a few tracks. in the past month I have also bought the ETS/EC 150/3 with new air stream 3 pad, MFK 700, the roll and a few odds and ends. also have the 36 vac.
I did use the 75 and the Sander on a board and batten job I did last week.
