Cutting laminated boards with the ts75 blade recommendations
mikante
Hi, is any of you having experience hot to cut laminated boards with the ts?
what blade do you use in that case?
I'm having troubles achieving good results with a cmt/trition 48 hw tooth blade either.
Hi, not good with negative tooth Blades either. I always get small dents on the laminated surface, i m cutting plywood laminate. I tried a 48 alternate tooth blade and a 64 negative tooth like the solid surface blade you just linked, both Cmt blades but they are good quality. I tried several methods of cutting but none of these seemed to work for me.
I own a ts75 by the way.
