Cutting vinyl siding w/TS 55 EQ
Has anybody cut vinyl siding with this saw?  In the past with my old PC saw, I turned the blade around backwards and it cut like a charm.  I no longer have the PC and wondered if anyone has done it with the TS 55.
I used mine just about a month ago to do a small siding job. It was nothing but angles for the gable ends of a house. I used the blade for laminate flooring (only cause I didn't want to use my 48 tooth blades), installed normally. It cut really well. A little bit of jumping from time to time, but overall, it was fine.
Never thought about turning the blade around.
Sounds like a great way to cut thin vinyl siding.
Loren
