Tim Brennan
- Jul 28, 2013
I am cutting some circles of 18mm birch plywood using a router and then rounding one edge with a 6mm radius. Router bits are from the festoon set and have hardly been used if not new. The plywood has some rough surfaces and cavities, so I am applying some wood filler and then sanding it down. The trouble is that the filling takes 20 minutes and I have another 18 to make. I thought of the spray on filler but I don't have a spray booth. I am assuming this is happening because the plywood is not the furniture grade stuff - I paid £30 for a 8x4 sheet. I don't really want to spend much more than that.
See photos below for details.
Is there a better method that takes less time?
