Please update your website. Products that are already generally available don't have information in their corresponding product sections. For example, the MFT/3 has nothing (not even a picture) in the multifunction tables listings. Same with the OF 2200 router.
Also, you may want to run a spelling check on items before posting them. For example, the very first item that you see when you hit the site is the flash for the Kapex 120. "Riveling" should probably be spelled "Rivaling" (assuming that's what you meant). The next one (MFK 700) "One Motor, Two Basee" should probably read "One Motor, Two Bases". The RO 150 FEQ reads "Dual Mode: Geared Driven" and probably should read "Dual Mode: Gear Driven".
Yes, I'm bored at work.
