Toolpig
- Jan 25, 2007
Well, not for the "entire" floor, of course.
Normally, I'd pull off the shoe moulding on the baseboards and use my ROTEX 150 to edge-sand around the room and then use the rented floor sander to do the rest.
However, yesterday I got lazy and decided to try edge-sanding without removing the shoe moulding. The ROTEX wouldn't work because the bumper didn't have a flat surface to ride against and the pad was chewing up the shoe. So I pulled out my Deltex 93 and used is to sand right up to the edge of the shoe mouldings. PERFECT!! It takes a bit longer to edge sand with the DELTEX, but now I don't have remove all the shoe moulding and reinstall it (or cut and install new as the old stuff is pretty brittle). I saved a LOT of time with that little beast!
Worked great in the corners too with 40-grit Saphir!
TP
TP
