extiger said:
So, no one has a torque number of another drill for comparison purposes?
Although the US Milwaukee website doesn't seem to have the torque figures easily available, their
UK website does list them. Unfortunately the figures are in Newton metres (Nm) rather than inch pounds, and the model numbers are different, but it should give you the general idea. To convert from one measurement system to another, see
http://www.onlineconversion.com/torque.htm
Milwaukee mains-powered ToolsDrills/Percussion DrillsDrills 6 - 10 mm
HDE 10 RQX
Power input 725 W
Drill dia. in steel / aluminium / wood 10 / 13 / 30 mm
Drilling speed (full-load) 0 - 795 rpm
Tool reception 1 - 10 mm
Static stalling torque 63 Nm
HDE 6 RQ
Power input 725 W
Drill dia. in steel / aluminium / wood 6 / 8 / 16 mm
Drilling speed (full-load) 0 - 2680 rpm
Static stalling torque 30 Nm
Milwaukee mains-powered ToolsDrills/Percussion DrillsDrills 13 - 16 mm
B2E 16 RLD
Power input 900 W
Drill dia. in steel / aluminium / wood 16 / 20 / 40 mm
Drilling speed (full-load) 100 - 450 / 300 - 1000 rpm
Tool reception 3-16 mm
Static stalling torque 88 / 58 Nm 1./2. gear
HD2E 13 R
Power input 705 W
Drill dia. in steel / aluminium / wood 13 / 16 / 40 mm
Full-load speed 1st / 2nd gear 0 - 730 / 0 - 1540 rpm
Tool reception 1,5-13 mm
Static stalling torque 60 / 35 Nm 1./2. gear
HDE 13 RQD
Power input 825 W
Drill dia. in steel / aluminium / wood 13 / 20 / 38 mm
Drilling speed (full-load) 0 - 355 rpm
Static stalling torque 101 Nm
HDE 13 RQX
Power input 950 W
Drilling speed (full-load) 0 - 525 rpm
Static stalling torque 94 Nm
Here are the specs from the
Milwaukee UK 12v cordless drill/screwdriver range:
PDD 12 X
Battery pack voltage / capacity 12 / 2,0-3,0 V/Ah
No-load speed 1st / 2nd gear 0-400 / 0-1.300 rpm
Keyless chuck 1,5 / 13 mm
Drilling capacity in steel / wood 13 / 34 mm
Wood screws to 8 mm
Max. torque - soft joint / hard joint 22 / 50 Nm
LokTor S 12 PX
Battery pack voltage / capacity 12 / 2.0 NiCd V / Ah
No-load speed 1st / 2nd gear 0-420 / 0-1300 rpm
Drilling capacity in steel / wood / stone 13 / 34 / - mm
Keyless chuck 1.5 - 13 mm
Wood screws to 10 mm
LokTor S 12 TXC
Battery pack voltage / capacity 12 / 3.0 NiMH V / Ah
PLD 12 X
Battery pack voltage / capacity 12 / 2,0 V/Ah
No-load speed 1st / 2nd gear 0-380 / 0-1.250 rpm
Drilling capacity in steel / wood 13 / 31 mm
Wood screws to 8 mm
Max. torque - soft joint / hard joint 18 / 38 Nm
For Festool, the figures for the C12 and TDK are:
Cordless drill C12 3.0 Ah Set
Battery voltage: 12 V
Idling speed: setting 1: 0 - 450 rpm, setting 2: 0 - 1500 rpm
Max drill diameter: in steel: 9/16" (14 mm), in wood: 1" (25 mm)
Torque setting range: 17.7 - 61.95 in. lbs. (2-7 Nm)
Max torque: in wood: 159.3 in. lbs. (18 Nm), in steel: 265.5 in. lbs. (30 Nm)
Chuck capacity: 1/2" (13 mm)
Weight: 3 lbs. 13.4 ounces
Cordless drill TDK 12 CE
No-load speed: 0 - 430 rpm (low gear), 0 - 1400 rpm (high gear)
Torque setting range: 4.5 - 62 in. lbs. (0.5 - 7 Nm)
Max torque: in wood: 175 in. lbs. (20 Nm), in steel: 250 in. lbs. (28 Nm)
Weight: 4.4 lbs. (2 kg)
Cordless drill TDK 15.6 CE Set
Battery voltage: 15.6 V
No-load speed: 0 - 450 rpm (low gear), 0 - 1500 rpm (high gear)
Max drill diameter: in steel: 5/8" (16 mm), in wood: 1 3/8" (35 mm)
Max torque: in wood: 220 in. lbs. (25 Nm), in steel: 320 in. lbs. (28 Nm)
Weight: 5 lbs (2.3 kg)
Be aware that manufacturers may have different methods of measuring torque, and therefore comparing figures from one manufacturer to another can sometimes be a bit deceptive.
Forrest
