Ricky Blue
- Oct 21, 2025
Hi Everyone
I have just used the cross stops on my df500 and run into an issue.
This is the first time that I’ve used them for a long joint and found that the mortises became more and more out of alignment.
I checked for all of the obvious errors, but I’d followed the correct procedure.
So, started to check the set up of the machine and after a while I discovered that in order to get the pins in the cross stops to be equal distances from the centre line, I have to have one side set to 1mm less than the desired number and the other set to 1mm more than the desired number.
Therefore, if both are set to the same number it results in a 2mm compounding error.
If I switch the stops I get the same error.
Has anyone come across this type of issue before?
