Recently purchased the Domino 700 to use for joinery in lieu of my Lamello biscuit joiner. Starting to question that choice. Using any stock less than 1" thick results in cutter offset to one side which is very thin material and can lead to blowout. I have purchased Seneca shim plates and DF 500 cutter adapters but so far no joy. Only way I see to "shim" the 700 is to raise the stock workpiece by however many mm necessary for the cut. Short of cutting wood shims big enough on my table saw I really do not see that as a viable solution. Anyone else in this pickle? I'm beginning to think the Lamello biscuit cutter is a better choice for 3/4" and thinner stock when making cabinets than the 700.
