I'm building my first project with the Domino Connector set. So far, it's working out great.
The full set that I bought includes 20 8x36mm dominoes to use in mortises that don't need a connector. This project will only use 4 of those dominoes. In a larger project that I'm planning, I might use the remaining 16 dominos and need more.
Festool sells a pack of 130 8x36mm dominos for $19, but I already have most of a pack of 130 8x40mm dominos left over from past projects.
So, I'm wondering if I can use my 8x40mm dominos in the connector environment instead buying a new pack of the 8x36 ones. In using the connectors, one board is mortised to 15mm deep on the face and the other to 28mm deep on the end. That totals 43mm which should be sufficient for a 40mm long domino (especially since the dominos are usually shorter than the nominal labelled length). While it seems like to should work, it would also seem that Festool wouldn't have created this custom size just for use with the connectors.
Does anyone know what the deal is here. Has anyone actually tried using the slightly longer dominos with the connectors? I'm not averse to buying the 8x36 ones if I need to but I already have a lifetime supply of the 8x40 ones and limited space in my domino Systainer.
