Thank you [thanks] everyone for the kind words and compliments and yes, I'm indeed proud of this table which I built for friends moving into their new home at the end of May.
Some comments:
Peter, I really do not mind you enhancing the colour of the table. Oregon Pine / Douglas Fir gets darker as time goes by and in a few years it will be the same colour as your doctored picture in any event [smile]
I was always under the impression that Oregon Pine (as opposed to Douglas Fir) would be the common name in the US since the lumber originated from the state of Oregon?
Concerning the end grain and copper squares:
The legs are in fact hollow (ex 22 x 132mm) and the end grain is just 13mm thick glued to a 22mm Supawood base below. Much easier this way and one can select from and use all off-cuts to create the end grain patterns. This detail also allows the South African Pine subframe (which is behind the side panels with the copper squares canted 45º) to pass through the legs to form a unit. The legs and 35mm thick outer beams is likewise a unit and the 22mm top drops in between the outer beams.
The 16 x 16 x 2mm copper squares are purely decorative and do not cover screws. My initail design was to have these copper squares also on the drop-in top, three rows - a row at each end and one in the middle (= 18 Nº) but I was overruled by my two designer daughters! They did not want squares at all - in their opnion these squares would have stolen the limelight from the main feature of the table which is the end grain legs. Fortunately we reached a compromise...
