Bob Marino
- Jan 16, 2007
As most know, Festool has discontinued most of their 8 MM Router Bits.
I have these in stock - but not available on the web, so Paypal or check works. Hopefully, that won't be an issue.
Here they are via skew number. I will get the description and prices when I can get them up.
490 978 6 mm spiral
490 942 4 mm slot cutter
490 996 20 mm DT
491 009 18.7 mm roundover w bearing
491 021 31.7 mm cove
491 026 24 mm chamfer/edge trimming
491 067 6 mm dowel
491 068 8 mm dowel
491 137 42 mm false raised panel bit
491 138 42.7 mm raised panel bit w/o bearing
491 131 36.7 classical ogee w/bearing
491 134 17.5 mm roundover bit w angled bearing
Bob
490 978 6 mm spiral
490 996 20 mm DT
491 067 6 mm dowel
491 068 8 mm dowel
Bob
