whgmkeller
- Jul 3, 2018
Hi there. Willem here, from Netherlands, Europe. I'm a new forum member, did only just discover this forum a week or so ago. Have been reading useful stuff already, now I'd like to pose some questions.
I like to build wooden stuff, just as a hobby. Am now working on a new workbench and have plans for a BBQ cabinet later on and lots more ideas
The workbench is 2 meters long x 1 meter wide. I'm thinking the height will be somewhere between 90 and 93 cm's. In inches: 78,74" long x 39,37" wide x 35,43" high.
I'd like to have an mft/3 style top (will probably use the PARF system for that). But I don't think I will use the whole top as an mft/3 as I also have to do some hammering, nailing and other actions that take force, and I don't think an mft/3 MDS top is suitable for that. So I'm thinking I will simply divide the top in two areas: 1 x 1 meters mft/3 style and 1 x 1 meters hardwood.
This leaves me with two questions:
1 - The original mft/3 has aluminum profiles on all sides. I'd like to use these as well as this gives me the possibility to use Festool tools such as a guide rail or so.
In my intended setup, I can only have profiles on three sides as the fourth side would be sitting against the other hardwood part of the top.
Would this pose a problem? On all pictures of the mft/3 I've seen, people only seems to be using three sides.
2 - The original mft/3 is open from underneath. Even when you use it folded (sitting on the floor), the aluminum profiles create a space underneath the top.
In my intended setup my diy mft/3 would be sitting on top of the workbench, with no space underneath.
Would this pose a problem? I would of course not be able to clamp tools down from the underside, but I've read that there are clamps (PARF?) that can be tightened from above?
Or would I need to build a frame with the profiles on the sides and the mft/3 style top, and sit that on top of the workbench?
I'm looking forward to your suggestions
Thanks !
Willem
Willem
