Does the Carvex get hot?
JonathanJung
I'm looking for a jigsaw that can handle hours of continuous cutting of 4/4 hardwoods. Without getting hot.
The Bosch JS572EBK is a great saw, but gets so hot I have to keep taking breaks. Even wearing gloves isn't enough. It's a wonder it doesn't shut itself down. I've got a handful of different blades to try from.
Would the Carvex, Mafell, or other option be up for this? For my application a bandsaw won't work. I don't mind stopping once in a while, but with my Bosch I'm stopping every 5 minutes.
If the Bosch can't handle this, I can't imagine a saw that can. I certainly wouldn't try the Carvex instead. Dunno about the Mafell though, I got no experience with that one.
But, sawing 4/4 hardwoods for hours after eachother, are you sure a jigsaw is the proper tool for the job? What kind of things are you making, what kind of shapes do you need to saw? Some kind of circular saw / table / slider seems to me like it could handle the long duration a lot better.
I use the jigsaw to cut flowing lines from multiple pieces made into a larger panel:
grobkuschelig said:
Bandsaw?
Will be much quieter as well. ;)
I would but the method used for cutting these doesn't allow for it. And trying to cut exactly to a line with a 7' board would be really hard.
Yep, that sure is hard to do with anything else than a jigsaw.
My solution would be to get multiple jigsaws. At least 2, maybe 3. Maybe 4. I don't know, give them plenty of time to cool down while you use another.
Hi,check out how jory brigham did his organic bed on youtube. nice panels.guy
I do know my Trion does get hot. But the Carvex will probably not run as hot as it has a more efficient brushless motor. Less waste = less heat. But I don't think any jigsaw was designed with your usecase in mind.
The Bosch isn't brushless right?
Either way; they all have a fan, that will have influence too.
Multiple jigsaws might be the way to go...or this!
Bosch 7561-118 pneumatic jigsaw. $600, easier on the hands, avoid buying multiple jigsaws...but will have to add a bigger compressor to my cart...
From what I can see, pneumatic tools are going the way of the dodo. Corded isn't half as annoying as 'pressure-hosed'. Even in factories where pneumatic tools are used a new use-case is often easier served with yet another Bosch GSR 12v-15 over adding another compressed air hose on a reel.
Get a Mafell.
I was recently doing a lot of cut outs in 4/4 walnut with P1CC and I couldn't feel even the slightest resistance. It was like going through cardboard. Mafell eats it for breakfast. And the cut quality is amazing. Of course I wasn't cutting crazy fast, just as fast as I could to precisely follow my lines.
Here is an example of a hand guided straight cut with Mafell P1CC in 4/4 walnut. I could not get this quality of cut with any other jigsaw, Carvex included.
That one's not easier on the hands, that body is terrible. And you always have to hold the lever.  Noise of the compressor will also irritate incredibly. $600 for a saw and a new compressor, that's gonna add up. For that money you can buy 2 Mafell jigsaws and feel like you're in heaven.
The answer to your question is = Mafell P1CC. That is all. As an added bonus, your cuts will be 100% square to the surface. No leaning, no blade wander, nothing. Use a down-cut blade and turn the pendulum action to zero.
I'm also of the opinion that having more than one to deal with the length of work time you need is the best solution...while cutting with one, the other can be cooling down. Tools like this were not likely ever designed for continuous use. Per my recommendation at that other place, I'd stick with the same tool so the function and feel is the same as you switch between them.
Yeah a couple saws is the way to go. The Mafell also gets hot as do most barrel grip saws. I like it the best. A top handle might help you endure long sessions better.
This is very helpful info. Anyone else have the Mafell and can comment to its heat buildup over long use?
I don't know the Mafell, but it is just a law of nature that tools get hot.
Lots of movement means lots of friction, which means lots of heat. The Mafell might be a good saw, but it doesn't have a magical fridge on board that other saws don't have.
Hi Jonathan - ignore the ludicrous 'two saws for use whilst one is cooling down' posts. Or maybe these are coming from the lottery-winner guys who have two of everything - just in case. Two Fisker-Galpin Rocket Mustangs. "Yeah. I bought another one just in case the first one's ashtray got full or the windshield got a splattered mosquito on it" .........
Everything with a motor will obviously get warm to some degree. My experience (based on 3 years use/abuse/torture of my P1CC) is that it never gets hot enough to make me feel that it's getting outside of its comfort zone. I've used it on numerous site jobs, cutting multiple birdsmouths in 12" x 4" roof rafters with a 150mm (6") long blade on roofing jobs for maybe 4, 5, 6 hours - literally nonstop - and it was barely warm to the touch. It obviously has a lot to do with the blade, material type, cut type (rip or crosscut), and quality of cut you need - faster/rougher or slower/finer. Everything the company makes is aimed at the pro user and is over-engineered accordingly. It's a stunningly good jigsaw which really sets the bar way high. The real competition-killer is the blade clamping mechanism. It's literally the only jigsaw out there which delivers cuts which are consistently 100% square to the surface. It works with all standard Bosch-type bayonet blades, and Mafell also make a specialist blade called the 'Cunex W1' = 2 x blades welded together for ultimate stiffness and day-long use without machine fatigue. Seek a P1CC out and try it if you can. It even comes in a proper T-Loc Sys 1 Systainer instead of the new Sys3 nonsense .........
Oh - and I checked out your website. Lovely work.
No affiliation - just a very happy and 100% satisfied professional user.
https://www.mafell.de/fileadmin/use...oge/Saegen/p1cc/Broschuere_P1cc_EN_1019_s.pdf
Cutting 2x material the P1cc gets mildly warm where you barely notice it.
Cutting 5/16” thick aluminum it gets a little bit warmer but nothing excessive or a need to glove-up.
Putting it another way, I’ve never thought about it before until you brought it up and then I had to think hard about it.
On the other hand, the original Fein multi-tool with the aluminum body/head was a glove-up tool and I’d be prepared every time I used it.
