Domino 500 Cross Stop Fix
griph0n
When doing multiples (54 Drawers, that's 216 parts, that's....about 1300 plunges)
The Cross Stops need to be checked constantly or they loosen up and fall off.  I started to tighten them up by rotating the internal cam, but that's hard on the plastic.  Now I replace the small internal cam every once and a while and that keeps them going.  I think they cost a dime each when i bought 20 from festool parts.
This drawer session I came up with a new fix with stretchy 3m tape.
Too bad there is not a robust alternative like the Domi-plate.  I've seen the woodpeckers but it is a little overcomplicated, expensive and not available.
Just thought I'd share my simple fix.
Can a rubber band do the same trick?
Nice shelving system for the storage of the panels! Did you have the shelves custom-made?
Next time I buy Broccoli I'll try the rubber band.  The racks are from Richelieu my hardware supplier.  Reasonably priced.  I used to use them for spraying.  Now I buy prefinished baltic Birch and just wipe the edges a few times.
