Kwomer2000
- Jun 21, 2016
Why did festool change from pins to the paddles on the 500 fence? Tried a search and couldn't find an answer. I have the paddle system, but if I could choose I would have chosen pins.
Kevin W. said:Why did festool change from pins to the paddles on the 500 fence?
Frank-Jan said:There have been a bunch of threads about the subject in the past. It's about a patent held by mafell, festool copied the indexing pins of their duo doweler machine.
antss said:Like fix kapex, like keep metric tools available in the U.S., like offer the full range of accessories, like keep the planer stand, like keep the small planer available, like add plug it to that planer, like make of2200 work with the router table, like bring the TS module for the U.S .......and on and on
Kevin W. said:What keyword(s) on the search engine? I'd like to read these threads. I used pin style fence and paddle style fence. That search engine leaves a lot to be desired.
antss said:Um"............how is glue getting into these pins ? [blink]
Certainly one is not morticing a hole , filling it with glue and then making another hole ?
And presumably the same thing would happen on the 700 no? But it's a different design you say? Ok, but then why wasn't that design incorporated on the 500 instead of the plastic tabs ?
Seems like a lot of corp. double talk in that response. And since when has FT ever been a champion of listening to customer feedback and adjusting their offerings?
Like fix kapex, like keep metric tools available in the U.S., like offer the full range of accessories, like keep the planer stand, like keep the small planer available, like add plug it to that planer, like make of2200 work with the router table, like bring the TS module for the U.S .......and on and on with no results and often no comments from the suits. They do what they want, or are forced to. The rest is just lip service.
Miss plunge, glued without test fit.
antss said:Miss plunge, glued without test fit.
ok, I suppose we've all been there - but so many guys at such a groundswell that the whole product needs a re-design ? Ya didn't learn your lesson the first time ?
And tell everyone about it ?
And FT's first response wasn't to produce a "training" memo and educate the masses on the "proper" use of their tool. Like that "workaround" for the issue they are having with the ill fitting guide rails because the spine widths are not consistent ? Or how about that new hose end that leaks like sieve on legacy equip. AND leaves sawdust caked in its grooves to dirty your workspace when removed ?
What was the official response ? Sorry you'll just have to lump it.
Management's first response wasn't "hey, thanks for identifying a manufacturing problem we have - we'll jump right on an improvement" It was: "you guys should check out our instagam channel for a video from our trainers on how to make yours work because we don't want to be bothered with pesky details or make real improvements". I think the FT we all know and love would have just done up a video on how guys should a. dryfit their work, and b. if that fails, clean your domino pin receptors thoroughly immediately afterwords to avoid them seizing up.
This issue also begs the question I've raised before about beta testing ? Do they do it and just who is putting these things through their paces? And , more importantly, why do those testes rarely (never) seem to encounter issues that FOG members seem to turn up within weeks of a product's NA launch ??? ??? ???
Maybe I am wrong, but if so, where did the festool that took user feedback on the domino and actually did something with it disappear to ? ??? ??? ??? ??? ???
What manufacturing problem?
You are fortunate. Many guys do not, especially those with recent delivery. See above.I have 36 guide rails, all of them fit together just fine.
How is this Festools fault user don't use the tool properly?
People who beta tested tested within the parameters of the tool(s)?
Probably because we make up the majority of this board and are a big marketplace as well. Law of averages and whatnot.How come it's in NA most of these issues arise?
antss said:What manufacturing problem?
how bout this one:http://festoolownersgroup.com/ask-festool/guide-rail-saw-tracking-when-connecting-rails/
It's not. Their M.O. recently though has been not to "improve" a tool because customers are ignorant or stupid or lazy; but rather re-educate the users in proper procedure. That's my point. And, why has only domino been 'improved" because of this feedback and most/all of the other pleas go unanswered or just ignored ? Under current procedure the answer to glued pin issue realistically would have been " don't glue pins domino users, they weren't designed for that" .
Of course they are , but maybe the parameters are substandard. Do you honestly expect us to believe that the new vac connector is designed to leak ?
Seriously ?
And to accumulate so much dust in the grooves that a mess is made upon disassembly?
Get real.
FT knows of this yet has done absolutely NOTHING. And the solution doesn't require engineering, or non billable time, or even expensive re-tooling. It only takes making the previous connector available again. How come FT can't be bothered with something as easy and simple as this , but they can undertake a fence re-design and re-manufacture for guys who can't use their tool correctly?
Noticing that stuff is not ignorance or mental capacity or training that can be chalked up to Nationality. It's either testers sticking their head in the sand or being biased/ less than honest about the performance -or- there really wasn't any real world testing going on. Which, is what I suspect is really the case. Because if there was, problems like the glued domino pins and leaky, dusty vac connectors would have showed up !
Kevin W. said:Thanks Cheese for the help with my question about the domino 500 pin style fence.
