thanks for that wow, The domino 700 is for sale on ebay for 811 dollars with free postage, not sure if I'll have to pay anything on top once it arrives in the uk though :/wow said:The plug-it connectors are the same, so yes, you could use a UK cord on a US tool.
There are also inexpensive plug adaptors available to convert US plugs to the UK style. They are available from Radio Shack for a couple of bucks, but they are also available in any UK airport or electronics shop that I've ever been in.
jobsworth said:So ya might need to pick up a tranny.
thanks for all of your inputs. Having read them all, I think the sensible option would be to wait and get one from the uk! At least I won't be taking any of the gambles mentioned beforehand. Having the forum can help you spend money :/ but it can also save you from wasting it!shed9 said:A transformer will set you back about £50 or less.
However, I agree with Gary in Texas, I would just opt for the country specific version. I suspect your warranty will be affected in this situation.
If you get stung by customs this may be a useless bargain gamble.
Gary in Texas said:As several have posted, you will need a step down transformer if you are planning on using a 110V product on the 220/240 UK voltage. A good transformer can/will cost you several hundred dollars, and the thing will be quite heavy!!! There is also the issue of hertz, the USA is 60Hz, the UK is 50Hz. The difference in Hz will cause your domino to run slower, which might lead to issues with making the mortise - think slower plunge/less bit RPM. If me, I would just opt for the unit designed for the voltage in the country you live in. Cost of a good transformer I think would negate the savings on the domino.
GH
