Jeff Wright
- Jan 22, 2007
I am unable to accurately calibrate the Domino's sight glass used to mortise freehand. I have tried moving the sight glass left and right with no success. I've moved the sight glass all the way to the right, all the way to the left, and points in between. Before making any changes to the machine's calibration, I did 8 test cuts where I drew a line between two adjoining pieces of wood (as if you were doing a rail and style build). All 8 cuts had the upper pencil line on the right versus the line on the bottom piece, showing that the error was not in my technique. Do you have any secrets about how best to adjust the sight line precisely? My only current solution is to not use the tight mortise setting at all when doing freehand but instead set it to the middle setting for the slot size and manually adjust the alignment of the wood pieces. Thanks.
