Domino connectors
Great thanks Phil,
very clever, cost is about £3 each,
looks like the grub screw works like a draw peg and pulls joint together as you wind it in!?
Bhend18 said:
What's the thinest stock these can be used in?
Pretty much as [member=40772]Holmz[/member] assumes ...
From the product page ...
The corner and flat connector system for the DOMINO XL DF 700 joining machine enables stable connections that can be separated again at a material thickness of 30 mm or higher
... I dare say that depending on the success of these larger items, Festool may refine it and make something for thinner stock. It wouldn't have made sense to introduce something in direct competition with existing stuff in the market. Give it 12 months and we'll probably see the Domino Micro Connector [wink] [big grin]
OK. I'd like to see some for 19mm eventually.
Holmz said:
For sheet goods [member=10890]Bhend18[/member] ?
No, for solid stock. I make baby beds with 19mm rails and I would use them to connect the rails to the posts.
