J Jack01 Member Joined Sep 7, 2013 Messages 56 Jul 24, 2022 #1 I am in process of joining 2 thin boards which are 10 mm in height. I started working on Domino DF 500 fence and realize the fence will not adjust to 10 mm Lowest I can go is 15 mm Is there any trick to adjust to 10 mm ?
C ChuckS Member Joined Sep 7, 2015 Messages 6,146 Jul 24, 2022 #2 Add (double-face tape) a shim of appropriate thickness to the bottom of your fence, something like this (the ply in the image is 5mm): [attachimg=1] Attachments DF 4mm support.JPG 29.7 KB · Views: 303
J Jack01 Member Joined Sep 7, 2013 Messages 56 Jul 25, 2022 #3 Thank you for your help, it did worked.
