Hi All,
I’m relatively new to the festool game having had a TS55 for a while now, but recently I seem to have accumulated shall we say a number of other festool tools one of which is a used DF500.
OK so since purchase I’ve watched countless YouTube vids by all the usual suspects, Festool UK, Festool USA (Hi Sedge
), New Brit Workshop etc.etc. but I settled on one from Rick Christopherson as my go to as he was using it to build drawer boxes just like I’m trying to do albeit using his own stop guide.
I’m using a 6mm cutter, 6x40 dominos with 18mm MDF, captive front and rears on the drawer box.
I get that the domino doesn’t have to be centred so for the front and back of the box I set depth @ 20 and plunge @ 25. I use the stops to register on the left and right of the stock, cutting 2 dominos , one tight and one on the next setting, dado facing down as per the vid. So far so good.
So for the drawer sides I set it vertical, dado towards me, as per the vid. Now here’s where it all goes wrong. The only setting I change is plunge depth to 15. I make the cuts left right, tight loose, and do a dry fit, this is all in ‘scrap’ by the way. When I offer up the side and the front the front sits like 2mm back from the edge. I end up setting the depth manually to get the alignment on the face to the side edge.
I’ve got to be doing something wrong or missing something but I can’t figure it out hence the reason for asking, so any help/pointers greatfully appreciated.
CG
CG
