deck building question number 2!
I'm probably going to use Garapa wood for my deck. (it is a very hard, rot-resistant Brazilian wood.) Because I can get a better deal on "short" boards (6' and 7' long) I'm wondering if I can use Domino tenons to join the ends of the boards between the joists, or at the joists? Does this make sense? The deck fastening system I'm using screws into the sides of the boards at each joist, so I'd fasten the decking down at every joist except where the joint is, and use a 10mm Sipo wood Domino there to keep the boards together.
