Oso Rojo
- Feb 27, 2014
I'm building some work tables out of double thickness of 3/4 play and lamination. I'm edge banding with 3/4 oak on the flat and 1.75 tall. This way I have 1/8 on either side to trim flush. I want to use dominos for alignment and ease of glue up. But I need the banding to have a different plate setting than the table top. For discussion let's say I need the table slot at 3/4 down, then the banding slot should be 7/8 down. I'd like these setting to be repeatable.
How do you recommend setting them? I don't think using the scale will be accurate enough. I was thinking of using one of the stops and a feeler gauge like spacer to get my extra 1/8"
Any thoughts for you guys with more experience at this?
