Modifications needed to use a 4mm bit to be centered in small stock
As standard when the fence is at 90 degrees the maximum depth permitted is about 7mm
This means that centering the domino in anything less than 14mm board is not possible. This is shown under
As you can see after the modifications there is no problem in centering the 4mm cutter in any stock
How to modify the fence:
There are two points where the movable section contacts the base
And of course two points on the base. The photo under is not quite a ?before?
I found the easiest way to hold the base for filing was in a WorkMate
And the best way to check where to file was using Engineers Blue
This shows where metal needs to be removed
There is one possible problem and that is that the restriction in travel is a design feature not an error.
As supplied the plastic guide can not contact any size of cutter however after the modification the user can destroy the guide if care is not taken.
I probably took off more than was strictly needed
4mm cutter minimum depth, no problem
10mm cutter minimum depth, destroyed plastic guide if you run the Domino.
